Cobot welding
Precision robotic welding for small series and single components
Modern cobot welding cells deliver unbeatable efficiency
In the manufacturing industry, collaborative robots, or cobots, have become indispensable partners in the field of welding technology. These welding robots are revolutionizing automated welding by putting efficiency, precision, and safety front and center.
Our innovative cobot systems are designed to adapt flexibly to your specific requirements in production. Whether you’re working with small, complex components or large, cumbersome structures, we offer the right cobot solution for every application.
The advantages of cobots
Low total cost of ownership
The cobot welding cells from Fronius are cost-efficient and soon pay for themselves, a key advantage for small and mid-sized companies in particular. Check out this blog post about cobot welding in small and medium-sized businesses for further insights into the economic benefits of the cells.
High flexibility
The welding cells are suitable for various component geometries and are easy to adjust to different production requirements.
Simple, user-friendly operation
You don’t need any special programming skills to operate the Fronius cobot welding cells. The user interface is intuitive and speeds up training.
Consistent, reproducible welding quality
Thanks to precise welding torch movements and intelligent welding technology, the cobot welding cells deliver a consistently high standard of quality, regardless of batch size.
Increased safety
The welding cells are equipped with CE-compliant safety devices and ensure a safe working environment.
High flexibility
Increased safety
CWC-mobile cobot welding cell
Mobile cobot welding with a compact, safe, and certified machine
The Fronius CWC-mobile is the perfect choice for flexible cobot welding.  Thanks to its compact design and transport unit with retractable casters, it’s easy to move the welding cell between large components.
The system is CE-certified and complies with all legally required safety regulations. The integrated safety package includes not only the cobot’s power and torque limiter but also additional safety measures such as fume extraction, a movable glare shield (EN ISO 25980), and personal protective equipment (gloves, protective clothing, and welding helmet).
Thanks in particular to low investment costs and rapid programming, the welding table offers a cost-effective solution for small-batch production compared to traditional robotic systems.
Highlights:
  • Portable and flexible
  • CE-certified safety concept
  • Designed for collaboration
Download fact sheet
CWC-mobile system overview
Product image CWC-mobile
CWC-S cobot welding cell
The CWC-S delivers profitable results even with small batch sizes
With the CWC-S cobot welding cell, a cost-effective and easy introduction to automated welding is guaranteed. This welding cell combines the latest robot technology with the proven welding expertise you’ve come to expect from Fronius. Developed for use in small to mid-sized series production, the CWC-S is user-friendly and meets the highest safety standards. A compact design and easy programming make this the ideal solution for companies looking to optimize their welding processes while tackling the challenges of the skills shortage.
Highlights:
  • Low total cost of ownership
  • Cost-effective even for small batch sizes
  • Simple, user-friendly operation
  • No programming knowledge required
  • CE-compliant safety housing
Download fact sheet
CWC-S system overview
CWC-D cobot welding cell
Flexible and productive cobot welding with the CWC-D
The Fronius CWC-D cobot welding cell is designed for cost-effective welding, from small batch sizes through series production. The welding cell is extremely flexible, offering one-station operation for large workpieces or two-station operation for setting up and welding in parallel. Programming is made easy using drag and drop, with no prior knowledge of robot programming required.
Highlights:
  • Two stations for high productivity
  • High flexibility thanks to expanded working area
  • The entire cobot welding cell comes CE-certified as standard
Download fact sheet
CWC-D system overview
Product image CWC-d
CWC-Extended
We custom-design CWC-Extended cobot welding cells for applications outside the scope of our CWC-mobile, CWC-S, and CWC-D variants. The system solution is based on modular components and is precisely tailored to the customer’s specific component, welding process (MIG/MAG or TIG), and manufacturing requirements.
Depending on the application, it is also possible to integrate elements such as tracks, positioning units, or multiple stations. This enables operators to reliably weld even complex component geometries with consistent, reproducible results, while benefiting from intuitive handling and minimal engineering effort.
Other topics
Illustration from Guide & Press: A component with red dots marking the welding path.
Guide and press
Define welding paths easily and conveniently
Guide the welding torch to the start, contour, and end points of the desired weld seams, and press the confirmation button on the control handle. All points are automatically applied to the welding program.
Person defines the welding process for a Fronius cobot welding cell using drag & drop on a tablet.
Drag and drop
Intuitive programming of welding processes
Simply drag icons such as Handle Teach, Basic Arc, or Basic Wave into the desired position in the graphic programming interface. Using this method, you can define the entire welding process without any in-depth programming knowledge.
Welding parameters at the touch of a button with the Fronius WeldConnect app.
WeldConnect app
WeldConnect makes it quick and easy to find the right welding parameters. The app guides you step by step through entering details such as the welding process, base material, weld seam profile, and shielding gas. The wizard then uses this information to calculate the optimal welding parameters.
Pathfinder
Boost productivity with Fronius Pathfinder
When using cobot welding cells, offline programming offers the advantage of creating and testing programs without having to stop ongoing production. This minimizes downtimes while boosting productivity. Finished programs can simply be transferred to the welding cell and adjusted directly on the cobot if needed.
Learn more about the Fronius Pathfinder
Fronius Pathfinder on laptop screen
