Solar.start
Support
Close-up of Fronius inverter at sunrise
Account & login
Yes, your Fronius user account is valid across all platforms and can be used for the Solar.start app. A separate account is not required.
If you are unable to register or have not received a verification e-mail, watch this how-to video on creating an account first. If you continue to experience problems, please contact our customer service team via the contact form providing the e-mail address used and a description of the error message.
How-to video: Creating a Fronius account (using Solar.web as an example)
Please make sure that the registration process is complete. After registration you will receive an e-mail containing a confirmation link. Open it and complete the first login process by filling in the rest of your details.
If you have already completed your registration, please use the ”Forgot password?” function in the Solar.start login area.
If this does not work, please contact our customer service team using our contact form and include the e-mail address associated with your user account.
No access to this e-mail address?
Please also send us a scanned copy of a valid ID document. This is for security reasons, as confidential data can be viewed in your account.
Solar.start herunterladen
Google Play StoreApple Store
Troubleshooting
Check whether you are still connected to the inverter WiFi (network name Fronius_XXX, where XXX stands for the serial number or data source ID). In this case, it is not possible to access the Internet. In your WiFi settings, switch to a network with an Internet connection.
The inverter has probably already been successfully connected. Your smartphone may not display this because it lost the connection to the inverter and has connected to a different WiFi network.
Check in the WiFi settings whether you are still connected to the inverter (Fronius_XXX, where XXX stands for the serial number or data source ID). If not, reconnect to this network and switch back to the app. The page should reload.
Alternatively, you can use the Back button to switch to the app menu and restart commissioning. You can continue from where you left off. The inverter should already be connected to the WiFi.
On iPhones or iPads, you have to connect manually by scanning the data matrix code in the app (Primo/Symo GEN24 Plus and Tauro) or by following the instructions in the app.
On Android devices, make sure that your device is allowed to connect to WiFi without an Internet connection. Confirm the system message if necessary. Check whether this option is available in the WiFi settings and enable it. The setting can also be found in the Developer options menu. For more information, refer to the operating instructions for your smartphone.
Make sure that your device is allowed to connect to WiFi without Internet access. You may have to confirm a system message. Check whether a corresponding option is available in the WiFi settings and change it if necessary. On Android devices, this setting can be found in the developer settings. For more information, refer to the operating instructions for your smartphone.
The inverter or Datamanager restarts during the update. The connection to your smartphone is terminated so status updates are no longer displayed. Look at the LEDs on the inverter or Datamanager to check the operating status. As soon as the device has restarted, you can exit the screen in the app using the Back button.
Contact & training
Contact
Can’t find what you need or still have questions? Our experts will be happy to help you.
Contact Us
Icon Tech Support
Training & webinars
Practical training for installers and Fronius Service Partners, in person or online with clear video demonstrations.
Go to the training
Icon Training white
