Fronius Charge & Connect
Intralogistics software solution
Man with a tablet
The digital connectivity solution for your charging infrastructure
Everything at a glance. With Charge & Connect, you can go beyond the limits of conventional charging. Our cloud-based software solution connects directly to your charging infrastructure and gives you real-time data on availability and status. Looking for more? Customize Charge & Connect with smart features that help you optimize your intralogistics. Unsurpassed transparency gives you total control over your traction batteries and chargers.
Full transparency for maximum charging performance
Added value from your charging data
Charge & Connect stores and analyses your charging data and visualises it in a clear dashboard. KPI evaluations and cross-location statistics highlight load peaks, application errors and optimisation potential.
Higher performance – less effort
Keep an eye on all charging stations automatically. Real-time notifications reduce downtime, and analyses help you to optimally design your battery pool and improve it in the long term.
Future-proof and flexible
Charge & Connect supports digital, data-based decisions and grows with your requirements. New chargers can be easily integrated, and automatic updates keep your infrastructure up to date.
Our Charge & Connect functions at a glance
Load balancing – reduce peak loads, lower costs
Keep the base load of your charging infrastructure stable and avoid power peaks. You define shifts and desired availability, and the intelligent algorithm automatically optimises charging times – for lower energy costs.
PV Connect – Sustainable charging with solar energy
Use PV surpluses efficiently to charge your forklift fleet. PV Connect lowers energy costs, reduces CO₂ emissions and makes sustainable charging easy at the touch of a button.
Battery Connect – Intelligent battery management
Monitor your battery fleet with minimal effort. Battery Connect immediately detects faulty batteries and problematic charging behaviour. Detailed reports help you increase the performance and efficiency of your charging infrastructure.
Cool Battery Guide digital – Easy to find the right battery
The digital Cool Battery Guide ensures optimal battery use. An intuitive LED display guides drivers to the battery that is ready for use, reduces incorrect removals and extends the service life of your battery pool.
