BlogExperience reportsSupport area
Hot Water
Produced with Photovoltaics
Use PV surplus and save money
Photovoltaic systems are true all-rounders, as the solar power generated can be used flexibly anywhere in the household. This also applies to heating water that can be used for showering or heating. In this way, you can use a lot of your own solar power and save even more energy costs.
Advantages of hot water with photovoltaics
Use more solar power
Instead of feeding surplus solar power into the grid, use it yourself to produce hot water. You therefore reduce your energy costs.
Protect the heating system
You extend the service life of your heating system because you can switch it off completely in summer. This also saves you money.
Be independent and protect the climate
Make use of your own clean energy supply.
Use more of your own solar energy
The electricity that you produce on your own roof is far cheaper than electricity from the grid. In order to permanently reduce energy costs, you should therefore use as much self-generated solar power as possible. Depending on the size of the system, an average household uses 20-40% of its own solar power.
By using surplus solar power for hot water production or heating, you feed less electricity into the grid. This allows you to increase your degree of self-consumption to over 60%. You give away less of your own PV power, have to purchase less energy from the public grid and save money.
PV electricity for air conditioning
Incidentally, it is not just heating, but also cooling with solar power that makes ecological and financial sense. If your air conditioning system is running at full capacity on hot and sunny days, your PV system produces a particularly large quantity of electricity, which can be used to operate the air conditioning system
Boy in bathtub
Protect the heating system with solar power
Whether you heat your home with a heat pump, a pellet heating system, with oil or gas - a photovoltaic system can support the heating system. Whenever there is a surplus of solar power, it can be used to generate heat.
This option even allows you to switch off your heating system completely during the summer months and you do not have to activate the entire heating system for small amounts of hot water. This not only reduces your energy costs, but also extends the service life of your heating system.
Heat pump & solar energy - the perfect combination
The perfect combination when it comes to heat from solar energy is a heat pump and our Fronius Ohmpilot
The heat pump is highly efficient and can generate up to 5 times the amount of heat from an available amount of electricity. The fast Fronius Ohmpilot consumption regulator can in turn control the heating element in your boiler or buffer storage tank with very small quantities of electricity. In this way, the device uses surplus solar power to keep the temperature in the boiler constantly high. This means that the heat pump does not have to switch on and off as frequently and is therefore protected over the long term.
Woman in the bathroom
How a heating solution with photovoltaics works
In this way the energy from your own roof can be used throughout the household.
Keep an eye on your photovoltaic system at all times
With the free Fronius Solar.web monitoring tool, you can keep an eye on your energy yield and consumption at all times and get the most out of your photovoltaic system.
  • Ensure functionality
  • Shorten the payback period
  • Expose energy guzzlers
  • Analyse and optimise energy consumption
  • Keep the system up-to-date
  • Save more money with individual extensions
  • Extend warranty free of charge
More about system monitoring
Solar.web bubble chart
Save by heating water with solar power
“Until a few years ago, we used the heating system only to produce hot water from April to October. However, we can also do this with solar power and switch off the heating system completely during the summer months.”
Stefan, system owner
Read experience report
man in the boiler room
