Fronius Tauro & Tauro ECO
Commercial inverter for large-scale PV systems
Fronius Tauro: Our robust inverter for the toughest requirements
Powerful in any situation: the robust Fronius Tauro string inverter impresses with maximum flexibility in system design alongside minimal overall system operating costs. Make commercial large-scale photovoltaic systems even more cost-effective with this durable project inverter.
Maximum performance, simple installation
Designed for single-person handling, the Fronius Tauro is remarkably quick to install and easy to maintain. Active cooling technology reliably protects the power electronics, extends the service life, and prevents potential derating. The double-walled housing also ensures optimum temperature compensation, even in direct sunlight. This keeps the inverter’s performance consistently high even at ambient temperatures of up to 50 degrees Celsius.
Fronius Tauro
Die Produktstärken des robusten Wechselrichters im ÜberblickVersions
The Fronius Tauro and Tauro Eco are both available in two versions. While the Direct (D) version enables the DC strings to be connected directly to the device and offers an optional arc fault circuit interrupter, the Precombined (P) version allows centralized system designs to be implemented.
Configure inverters for large-scale PV projects online with ease
Configure your Tauro in just a few clicks
Use the configurator to adapt the Fronius Tauro to perfectly meet the requirements of your PV system. Based on your configuration, we will create a customized quote for you and you can conveniently order your Fronius Tauro online.
Technical data & downloads
| Technical data | Fronius Tauro | Fronius Tauro Eco |
| Power categories | 50 kW | 50 kW |
| MPP trackers | 3 | 1 |
| MPPT voltage range | 400 - 870 V | 580 - 930 V |
| Max. DC voltage | 1,000 V | 1,000 V |
| String fuse | Integrated, 20 A or 30 A (only in the Direct version) | Integrated, 20 A or 30 A (only in the Direct version) |
| DC/AC surge protection device | Type 1 + 2 integrated, type 2 optional | Type 1 + 2 integrated, type 2 optional |
| Arc Fault Circuit Interrupter - AFCI | Optional (only in the Direct version) | Optional (only in the Direct version) |
| Grid connection | Single core, multi core, or AC daisy chaining | Single core, multi core, or AC daisy chaining |
| Cooling system | Active cooling and double-wall system | Active cooling and double-wall system |
| Protection class | IP 65 | IP 65 |
| Type of installation | Indoor & outdoor installation, vertical or horizontal | Indoor & outdoor installation, vertical or horizontal |
Everything at a glance
