Fronius Repowering Tool for PV systems
Back to full performance
Installer with GEN24 inverter
Repowering for PV systems: increase performance simply and efficiently
Many older PV systems are no longer working to their fullest: outdated inverters, limited monitoring options, and a lack of compatibility with modern technologies are common problems. With the Fronius Repowering Tool, you can replace the inverter and get the most out of your system.
What is Repowering for photovoltaics?
Fronius offers you an easy way to modernize your existing PV system. Replacing the inverter not only provides more power, it modernizes your entire system by adding compatibility for battery storage and other system components.
Repowering with Fronius at a glance:
  • Simple integration of Fronius components into existing systems
  • Modern technology for greater efficiency and safety
  • Connection options for energy storage device, e-mobility, and energy management
Installer mounting Fronius GEN24 inverter with solar storages
Advantages of our Repowering Tool
Icon Solar.web
More solar power
Modern inverters increase the efficiency, yield, and service life of your PV system.
Icon Reserva
Flexible expansion of PV systems
Open interfaces enable storage solutions and smart energy applications to be connected.
Icon GEN24
Easy inverter replacement
With the Fronius Repowering Tool, you can find the right replacement for your old device—easily, free of charge, and on any device.
Why choose Repowering with Fronius?
Repowering Tool
Free online tool for selecting the right Fronius inverter
Convert now
Active cooling technology
Active cooling technology protects the electronics even at high temperatures
Easy installation
Replacement without extensive rewiring significantly reduces both downtime and labor costs
Monitoring included
User-friendly Fronius Solar.web monitoring tool for easy maintenance and full control
Durable components
Quality tests and robust design ensure high reliability
Modular exchange
Replace just the power stage set or PC board without having to replace the entire device
Compatibility with older systems
Fronius devices are compatible with many existing PV systems, including those from other manufacturers
Repowering Tool
Convert now
Easy installation
Monitoring included
Durable components
Modular exchange
