Fronius Tauro configurator
The easy way to configure the Tauro
Tauro Configurator displayed on a laptop
Fronius Tauro configurator: quickly find the right solution for large-scale PV systems
Planning commercial photovoltaic systems is complex, as different requirements, variants, and technical details need to be considered. The Tauro configurator helps you and your customers plan the ideal Fronius Tauro inverter (including all options and accessories) for large-scale PV projects in a few simple steps.
Inverter configuration for large-scale PV projects
With the Tauro configurator, you can design a custom inverter model to suit the system architecture, installation type, and technical requirements. The tool provides you and your customers with a solid basis for quotations and orders as well as for further project planning.
You can use it to:
  • choose between a centralized and decentralized system design.
  • configure AC and DC connections, protective components, and mounting options.
  • integrate additional functions such as the arc fault circuit interrupter Fronius Arc Guard or AC daisy chaining to link several inverters together.
Technician standing on a rooftop next to an open Tauro inverter, working on the device
Advantages
The basis for quotations and orders
Your configuration can be used for quoting and ordering—no further amendments needed.
Custom project planning
The tool takes the requirements into account and designs a customized solution.
Quick and easy configuration
Find the right inverter for your large-scale PV project in just a few clicks. No prior technical knowledge required.
Functions
System design selection
Centralized or decentralized to suit the project structure.
Icon system design white
AC and DC connection options
Select daisy chaining, single core, multi core, AC disconnector, and much more.
Icon acdc
Integrated surge protection device
Choice between type 1+2 or type 2 protective components.
Icon shield white
Fronius Arc Guard Technology
Integrate arc detection for increased safety.
Icon arc guard
Different mounting options
Choose from horizontal, vertical, indoor or outdoor installation depending on the location.
Icon maintenance
Export function
Export your configuration as a CSV file or by e-mail for quotation and documentation purposes.
Icon download
Start planning large-scale PV systems now!
Click here to get started with PV planning.
To the Tauro configurator
More about the Tauro configurator
Frequently asked questions
Find all the answers to the most important questions about the Tauro configurator here.
To the FAQs
Icon Help Center
Webinar: Fronius Tauro for commercial PV systems
Find out all about the robust Fronius Tauro inverter, from the intelligent system architecture and flexible options to efficient servicing.
To the webinar
Icon webinar
