Circumferential welding systems
Close-up of the torch: Fronius FCW-Smart welding cell.
Mechanized circumferential welding systems for components of any size
We have the right welding system for every application. Our solutions are the ultimate in precision and efficiency, meeting the full scope of requirements for quality and reliability in tank, vessel, and pipeline construction in particular.
We also offer custom solutions that stand up to any challenge. Working with our mechanized circumferential welding systems, you can weld components of very different sizes and weight classes—thanks to systems ranging from compact welding cells for smaller components through to robust systems for heavy workpieces.
Cutting-edge technology and premium materials deliver top results, making our welding systems incredibly versatile, simple to use, and easy to maintain. Even welds, high process stability, and less rework are just a few of the advantages—and you can benefit too.
FCW Smart
L = 1,200 mm/860 mm (with tailstock)
Ø = 450 mm
payload = 300 kg
Learn more
FCW Compact
L = 6,000 mm (with tailstock)
Ø = 800 mm
payload = 300 kg
Learn more
FMW
L = 12,000 mm
Ø = ~ 1,300 mm
payload = 2,000 kg
Learn more
FCW Heavy
L = ~ 24,000 mm
Ø = ~ 4,000 mm
payload = ~ 15,000 kg
Learn more
Applications: Welding systems for tank, piping, and equipment manufacturing
Cylindrical vessels and components are used in many different industries, e.g., for storing liquids or processing bulk materials.
The modular design of our circumferential welding systems makes them an ideal solution for components with a diameter of 50 mm to 6 m and length of up to 25 m.
Base materials:
Steel, stainless steel, aluminum, duplex, nickel-based alloys
Industries:
  • Pipeline and vessel construction
  • Mechanical and equipment engineering
  • Food, chemical, and pharmaceutical industries, etc.
Different application fields; cylindrical containers and components
