Store solar power
Batteries for PV systems
House at night with lights on
Your energy when you need it
A battery storage system can significantly increase the self-consumption rate of the solar power you generate. At the same time, your energy costs are reduced because you are less reliant on electricity from the public grid. Your surplus solar power is stored in the battery for use during peak demand or nighttime hours.
The ideal choice for your perfectly tailored complete PV solution.To provide you with the best possible support in maximizing your self-consumption, we have developed our own storage solutions: the Fronius Reserva and Reserva Pro. They have been designed as the perfect partners to our hybrid inverters Fronius GEN24 Plus and Verto Plus and are available in various capacities. The lithium iron phosphate technology guarantees maximum safety and a long service life.
The ideal choice for your perfectly coordinated system PV solution.
GEN24 inverter with Reserva storage and Wattpilot Flex e-car charging solution
More security, more benefits
Optimize self-consumption
Use more of your own solar power and reduce energy costs.
Increase independence
Benefit from solar energy around the clock and increase grid independence.
Secure supply in the event of a blackout
In Full Backup mode, the battery is essential for supplying the household with energy even during a blackout.
Fronius storage solutions
Fronius Reserva Pro
Our scalable battery storage system delivers impressive charging and discharging performance for agricultural, commercial, and large residential applications.
Available capacities: 12.0 kWh – 32.0 kWh
Up to 128 kWh via parallel connection
Fronius Reserva
Our modular high-voltage battery integrates seamlessly into existing PV systems and, with its flexible storage capacities, offers the right performance for every private household.
Available capacities: 6.3 kWh – 15.8 kWh
Up to 63 kWh via parallel connection
Compatible partner batteries
Fronius inverters are also compatible with some PV storage systems from BYD and LG.
How big should my battery be?
The correct storage capacity plays a key role in achieving maximum self-consumption, greater independence, and optimal efficiency from your PV system.
The power consumption during the day must be taken into account. If family members are at home during the day and consuming electricity (such as working from home or running household appliances), a PV battery with a lower capacity is sufficient. If the home is mostly empty during the day, there is more surplus energy that can be stored for later.
As a general rule of thumb:
Average electricity consumption during the day
Annual electricity consumption in kWh / 1000 × 1.2 = storage capacity in kWh
Low electricity consumption during the day
Annual electricity consumption in kWh / 1000 × 1.5 = storage capacity in kWh
