Aluminum Welding
Stable connections, lightweight
Welding aluminum
Challenge of aluminum welding
Aluminum alloys are among the most commonly used construction materials in the metal sector, alongside steel. Their low weight, only about one-third that of steel, makes them particularly attractive for lightweight construction, for example in the automotive or aviation industries. However, welding aluminum poses a particular challenge: the surface is covered with a stable oxide layer that has a significantly higher melting point than the base material underneath. This combination complicates the welding process and requires precise process control and experience to achieve consistently high-quality results.
Interesting facts about aluminum
Pure aluminum (Al99.5) is not very strong. Adding other metals significantly increases its strength, allowing aluminum to be used in structures subject to high stress.
The protective oxide layer on aluminum can only be broken down using a positively polarized electrode, which works without any problems in MIG welding – in contrast to TIG welding, where this step is more technically demanding. Only inert shielding gases can be used for aluminum welding. Active gases would oxidize the melt and impair the quality of the weld seam. Particular attention must be paid to cleanliness: filler materials, workpiece surfaces, and shielding gas lines must be free of contamination. This is because aluminum reacts strongly with hydrogen, which quickly leads to porosity in the weld metal.
Welding of aluminium
Aluminum alloys at a glance
The most important components of aluminum alloys and their properties are:
  • Magnesium (Mg)
    0.3–7% higher strength, finer grain size
  • Manganese (Mn)
    0.3–1.2% better corrosion resistance, higher strength
  • Copper (Cu)
    roughly 5% higher strength, lower corrosion resistance, important for hardening capacity
  • Silicon (Si)
    12% for casting, reduces the melting point to 577°C, however with coarse grains
Magnesium, manganese, copper, silicon and aluminium
Checkmark icon
Advantages
  • Lightweight construction material
  • Good corrosion resistance
  • High thermal conductivity
  • Tough at low temperatures
  • Strength can be increased through alloying elements
incorrect x icon
Disadvantages
  • Strong oxide layer
  • Sensitive to pore formation – therefore difficult to weld
  • Higher costs, for example, compared to steel
Welding process for aluminum
MIG/MAG welding
Ideal if a higher deposition rate is required—for example when welding filler beads. More information about MIG/MAG welding
more information
TIG welding
For visually perfect seams and strong connections. More information about TIG welding
more information
Applications of aluminium
Vehicle manufacturing
Aviation
Construction
Shipbuilding
Aviation
Construction
Shipbuilding
Professional power sources for aluminum welding
TPSi-320i
TPS 320i
  • MIG/MAG welding system
  • Integrated data documentation
  • Intuitive touch display
Fortis 400
  • Reliable and stable welding performance for all manual applications
  • Easy-to-use digital user interface
  • Maximum connectivity
iWave 230i
iWave 230i
  • Alternating current TIG welding system from the new generation
  • Intuitive menu navigation
  • Can be expanded with optional function package
1 / 3
What Is aluminum welding with alternating current (AC)?
