What is
TIG welding?
TIG welding: clean seams, stable connections
Tungsten inert gas welding (TIG welding) is a gas shielded welding process and is one of the fusion welding processes. It is used wherever optimum quality and spatter-free weld seams are required. TIG welding is suitable, among other things, for stainless steels, aluminum and nickel alloys as well for thin sheet metal made of aluminum and stainless steel. Typical areas of application include pipeline and container construction, portal construction, and aerospace applications.
TIG welding: This is how it works
In TIG welding, the required current is supplied via a tungsten electrode, which is temperature-resistant and does not melt. This electrode emits an arc that heats up and liquefies the material. There is a nozzle for shielding gas around the electrode. The gas protects the heated material from chemical reactions with the ambient air. The noble gases argon, helium or mixtures thereof are used for this purpose. The inert, i.e. non-reactive, gases prevent chemical reactions with the liquid weld pool and the heated material. This ensures high-quality weld seams.
Since the tungsten electrode does not melt, the filler metal is fed separately during TIG welding – either manually or mechanically by an external wire feeder.
The tungsten electrode
So ist ein
WIG-Schweißsystem aufgebaut:
(1) Netzanschluss
(2) Stromquelle
(3) Schlauchpaket
(4) Massekabel
(5) Schweißbrenner
(6) Masseklemme
(7) Werkstück
(8) Zusatzwerkstoff
(9) Schutzgas
Process variants of TIG welding
Fronius Speed Cladding makes the coating process up to three times faster and more efficient than conventional methods. The result: shorter production times, lower costs, and a consistently high quality protective coating.
Which materials are suitable for TIG welding?
The most commonly used materials for TIG welding include stainless steels, aluminum and nickel alloys, and thin sheets of aluminum and stainless steel. For sheet thicknesses of less than four millimeters, economical welding speeds can be achieved with a mechanized wire feed. For thicker sheets, the TIG process becomes less economical – in this case, only root pass welding is recommended. More powerful processes such as MIG/MAG or submerged arc welding are suitable for welding the fill passes.
