Charge & Connect
connecting your charging technology
More efficiency, new transparency
Everything at a glance. With Charge & Connect, you can go beyond the limits of conventional charging. The cloud-based software solution connects directly to your charging infrastructure and provides real-time data on its availability and status.
Numerous analysis functions help you detect application errors at an early stage and derive measures to reduce costs and improve performance. Benefit from unprecedented transparency across all charging stations. Increase the performance and efficiency of your intralogistics.
Compelling Advantages for a competitive edge
CHARGE & CONNECT DASHBOARD
The current status of the charging stations at a glance in the Charge & Connect Dashboard.
Sustainably increase Performance with Charge & Connect
Push notifications
In order to be able to react as quickly as possible when problems arise in the charging infrastructure, it is crucial to be alerted to misbehavior at an early stage. Our digital networking solution Charge & Connect sends automated push notifications in the event of abnormalities in the charging infrastructure. This means that faults can be detected at an early stage - even without being on site yourself.
Minimizing downtime
The Charge & Connect dashboard creates transparency with regard to all relevant charging data. Thanks to this continuous monitoring of the chargers, downtimes of the forklift truck fleet can be reduced to a minimum. In addition, application errors can be detected promptly and avoided in the future.
Charge & Connect Features
The setup: industry-safe data transmission in real time
Gateway for data transmission
Each of our Fronius Selectiva 4.0 and SelectION chargers is equipped with its own Gateway and connected via Gateway Link. This enables secure and stable data transmission between the charger and the Gateway without interruption. Depending on your local conditions, you can transfer your charging data via WLAN or LAN. Using the company's own Internet, the data is sent to the Charge & Connect cloud and visualized for you in the Charge & Connect dashboard.
