The Outdoor Batterycharging solution
Fronius EnergyHUB
The Fronius EnergyHUB is the flexible and mobile outdoor charging solution
The Fronius Energy Hub is a mobile outdoor battery charging station that is efficiently installed in a special container. This makes it the first choice if, for example, you need additional battery charging capacity and there is not enough space in your hall to expand your existing charging infrastructure.
The Energy Hub is specially designed for outdoor use, it can withstand the most adverse conditions and is also available in a fireproof version. The mobile charging station is delivered to you as a turnkey solution, so it is ready for immediate use after connection to your power supply system. The wide range of configuration options allows you to adapt the Energy Hub perfectly to your requirements.
Your benefits with an Outdoor battery charging container
Flexible and ready to use
The Fronius Energy Hub comes turnkey. It is ready to use. You can charge and change your batteries immediately. Depending on your requirements, whether you are looking for a charging station with interchangeable module or want our fast visual identification Cool Battery Guide Easy on the outside of the Energy Hub, we tailor your customized solution for safe outdoor operations.
Safety and standard assessment.
The Fronius Energy Hub complies with the current safety regulations and is in accordance with the safety distances according to EN 62485-3. Optionally available as fire protection class REI 90.
Intelligent exhaust air and monitoring sensor.
Explosive gas explosions are no longer an issue for you. The intelligent exhaust air and monitoring sensors of the Fronius Energy Hub turns off automatically, when exhaust air requirements are exceeded. For your own safety.
Your full solution.
We plan and deliver your ready-to-use Fronius Energy Hub. We take care of the installation and safety-related approvals. Our service technicians are also happy to take care of the regular service and maintenance. Ask us.
