Individual and flexible
with modular charging solutions
Modular charging solutions ensure maximum flexibility for your intralogistics
Flexibility and agility are among the greatest success factors of today - especially in intralogistics. Not only the ability to adapt daily operations quickly but also the possibility to make the best use of available space and expand easily, are important influencing factors. With the aim of providing you the best possible support for your challenges, together with you we design your charging infrastructure that meets your individual requirements.
Optimum use of available space
When it comes to space and physical processes in intralogistics, a high degree of agility and efficiency is required. With Fronius, you have an experienced partner in the planning and realization of charging infrastructure and charging technology at your side. Thanks to the modular design of our charging systems the handling is particularly easy and space-saving. Based on your requirements, we plan your system solution in a holistical, sustainable and modular way. Safe and simple handling made easy.
Your individual charging solution
Innovative charging solutions at the next level
We know what is important in intralogistics. The high quality, attractive design and longevity of our charging systems will convince you. All our charging solutions are perfectly tuned to each other and guarantee the highest possible level of efficiency and availability. Besides, all components are manufactured in a sustainable way in Austria and fulfill the highest quality standards.
/ High-quality and modular:
With Fronius charging solutions, your charging station grows with your requirements and can be expanded almost indefinitely. Discover the variety of possibilities of our charging modules and racks and create your unique charging infrastructure, module by module.
/ Multifunctional and expandable:
Our charging modules and racks are multifunctional and can easily be used and expanded. They can be combined in a variety of ways with each other and are compatible with all our chargers. If your requirements change over time, you can always retrofit or reorder them.
CHARGING STATION You can reduce safety-related risks to a minimum thanks to the standards-compliant installation and equipping of the charging station. The central placement of all batteries and use of our battery management system, Cool Battery Guide Easy, enables optimum utilisation.
/ Easy assembly and disassembly:
The sophisticated design of our charging racks and charging stations allows for easy and fast assembly and disassembly. By this, our chargers can always be used where they are needed. Simply set them up on the new location, fix everything and start charging.
/ Reusable:
The high-quality components can be reused several times, ensuring maximum flexibility and sustainability. A special coating protects against corrosion and ensures longevity and resistance.
/ Space-saving and compact:
Our charging solutions are real space-savers. The compact design saves you valuable space in your storage rooms.
/ Adaptable to your spatial conditions:
Whether on the wall, the ceiling, in a stand or outdoors - place your charging solution where it best supports your work processes. For even more flexibility, we also offer mobile charging modules with fixable castors.
Highest durability and quality
For 75 years we have been known for our efficient and technologically advanced charging solutions. All our chargers and systems are manufactured in Austria and ensure maximum availability and reliability when charging traction and starter batteries. Very stringent endurance tests ensure that every Fronius product meets the highest quality standards, is free from defects and continues to withstand tough conditions. 
High-quality charging solutions that convince all along the line!
Reliable and long-lasting
Our systems are particularly robust and impress with a long service life and reliability in daily use.
Attractive design
Our charging solutions have a very modern and appealing design. They ensure a perfect impression in your company and during customer visits.
High load capacity and stability
The solid construction of our charging modules ensures a high load capacity and allows both small and large chargers to be safely attached.
The charging solution that grows with you
With our flexible charging solutions you are well equipped for future developments. Whether in single-shift operation with just a few forklifts or in multi-shift operation with a  fleet of forklift trucks - the Fronius charging solution grows with you. All our charging modules and racks can be easily expanded, adapted and reused. And there is more to it than that! Also our chargers can be retrofitted for new requirements -  whether with additional hardware or software. Together with you we develop your tailor-made charging solution which ensures maximum flexibility and optimises your workflows.
Always the optimum and standard-compliant solution
Safe and standard-compliant charging stations
The risk of accidents, damage and downtimes can only be diminished when chargers and infrastructure are optimally attuned to each other and meet all safety requirements. Only this way you can protect your employees and avoid expensive liability claims.
For all safety matters only trust real experts!
Additional capacity with mobile outdoor charging station
With Fronius charging solutions you can also manage short-term capacity constraints or space problems. The Fronius Energy Hub is a mobile battery charging container that can be quickly and easily installed outdoors. It is suitable for both summer and winter operation and is also available in a fireproof version. The wide range of configuration options allows you to adapt the Energy Hub perfectly to your requirements. The turnkey solution is ready for immediate use after connection to your power supply system.
Newsletter Subscription
