Fronius Wattpilot
Designed to move.
The electric car charger that always provides the cheapest charging
Whether you're at home or on the move, have your own PV system or not: the Fronius Wattpilot charges your electric car more flexibly and intelligently than ever before.
The Fronius Wattpilot comes in two versions:
- Home – the fitted charger for use at home.
Available in the 11 kW and 22 kW power categories. Just plug it in and let it charge.
- Go – the transportable solution for when you're on the road.
Both versions offer sustainable charging with solar or green electricity from the grid and help you to slow down climate change a little bit.
It's about e-mobility that drives us all forward. Fronius Wattpilot. Designed to move.
It doesn't get cheaper than this: Charge using your own solar power
As a PV system owner, you'll already be aware of the environmental and economic advantages of generating your own energy. As the owner of an electric car, you can significantly increase your potential savings with the Fronius Wattpilot. This electric car charger can switch between 1 and 3-phase automatically and regulate its output in 1 ampere steps. This allows it to make optimal use of the surplus PV energy from 1.38 kW to 22 kW and use any surplus energy from your PV system to sustainably charge your vehicle at virtually no cost.*
Your benefits: you save while you charge and make optimum use of your PV system so that it pays for itself faster.
* Additional components are required for PV-optimized charging. All details can be found in the operating instructions.
Two charging modes for flexible e-mobility
Charge your vehicle to suit your needs. The Fronius Wattpilot offers two charging modes which can be selected directly on the electric car charger or via the Fronius Solar.wattpilot app:
- Eco Mode
The preferred mode for PV system owners. It ensures that your vehicle is charged – whenever available – with self-generated solar power or the cheapest mains current.
- Next Trip Mode
Next Trip Mode is for those who want to reliably charge their electric car to cover a specific journey – a certain number of kilometres – by a specific time. The Fronius Wattpilot reliably and intelligently charges the required amount. If available, surplus PV power from your own PV system is used or the cheapest mains current.
Optimal power distribution – with Dynamic Load Balancing
Whether with excess energy from your photovoltaic system or with power from the grid, Dynamic Load Balancing allows you to use the entire available amount of your household electricity optimally. With one or more installed charging stations, not only can you charge your electric cars at the same time, but also in an energy-optimised manner. The energy required can be controlled and distributed dynamically among up to three vehicles being charged. The advantage for you is that both the performance of your photovoltaic system as well as the energy consumed in the household are taken into account. This saves high connection costs and also effectively prevents overloading at the house connection. And best of all, thanks to Dynamic Load Balancing, you can prioritise precisely and therefore achieve even higher charging power.
The electric car charger for at home and on the road. Discover useful functions and features.
Solar.wattpilot – the app for the charger
As flexible as the charging solution itself – control the Fronius Wattpilot with ease from your smartphone or tablet:
- Easy commissioning of the Fronius Wattpilot
- Clear display of all charging data
- Select a charging mode anytime, anywhere
- Change settings with just a click– Software updates made easy
"I use the Fronius Wattpilot to charge our electric cars with surplus energy from the PV system. Charging costs us practically nothing. We can fully charge both vehicles in one weekend and drive them the whole week for free. Fronius Wattpilot controls and manages it all – I think it’s amazing."
Franz Dietachmair,
Electric car driver and Wattpilot user
The Fronius Wattpilot and sustainability
The Fronius Wattpilot is a key part of our product portfolio, enabling 24 hours of sun – for a world which is 100% based on renewable energy, without exception:
- The Wattpilot electric car charger promotes emission-free mobility and helps to slow down climate change
- With your own PV system and the Fronius Wattpilot, electric cars can be charged independently and sustainably
- Adjustable modes enable particularly resource-conserving charging processes.
All versions of the Fronius Wattpilot
| Data | Wattpilot Go 11 J | Wattpilot Go 22 J | Wattpilot Home 11 J | Wattpilot Home 22 J | |
| Max. charging power | 11 kW | 22 kW | 11 kW | 22 kW | |
| Dimensions (l x w x h) | 28,7 x 15,5 x 10,9 cm | ||||
| Mains connection | CEE16 plug red 5-pin 30 cm incl. neutral conductor |
CEE32 plug red 5-pin 30 cm incl. neutral conductor |
5-pin cable 180 cm incl. neutral conductor |
| Optional adapter sets | CEE32 red fused, CEE blue camping plug, safety plug 16A |
CEE16 red, CEE blue camping plug, safety plug 16A |
| Network connection | WLAN | ||||
| Installation type | Hanging upright, flexible portable |
hanging upright, |
| Use | Indoor & outdoor | ||||
How to get your electric car charger
Find an installer in your area who can advise you on the right Fronius Wattpilot version and also carry out the installation straight away.
Our Fronius Partners are certified installers who offer top-quality advice, installation and service.
Simply share your location or use the search function and find the right Fronius Partner.
