Fronius backup power solutions
Reliable power supply in the event of a blackout
Hell erleuchtetes Haus dank Fronius Gesamtlösung, umgeben von dunklen Häusern ohne Strom.
Don’t be left in the dark when it matters most
Blackout? Backup! A power failure doesn’t have to bring everything to a standstill. It all comes down to the right preparation. Whether for your home or your business, our intelligent backup power solutions ensure you can rely on your power supply even during a blackout. This not only stabilizes the infrastructure, but also provides future-proof backup power from solar energy. After all, true energy independence starts where reliability meets innovation.
Fronius backup power solutions: energy self-sufficiency in a power outage thanks to solar energy
Independence begins on the roof: Fronius helps you build a PV system step by step that reliably meets your everyday power needs and offers security in exceptional situations. From the basic backup power supply in every Fronius GEN24 inverter to the Full Backup option that automatically supplies your entire home, you decide how far you want your independence to go today with forward-looking, efficient products all from a single source.
3 Personen freuen sich über ihre Fronius Notstromlösung, ein Fußballspiel läuft am Bildschirm
The advantages for you
Stable power supply...
...to the most important loads or the entire household, even when you’re not at home.
Future-proof planning...
...to suit your needs. Designed for longevity, our systems allow backup power to be added or expanded at any time.
Data protection...
...thanks to the highest safety standards. Your data is stored exclusively on European servers.
Data protection...
Backup power options and products
Simply secure: basic backup power supply
Our Fronius GEN24 and GEN24 Plus inverters come as standard with PV Point, a basic backup power feature. During a power failure, energy is supplied to selected single-phase loads via a designated socket, without the need for a battery. For added convenience, PV Point Comfort continuously supplies selected electrical loads during normal grid operation and in the event of a power outage.
Ein Mann aktiviert seine Fronius Nostromlösung
PV Point
An integrated basic backup power supply that supplies energy to single-phase loads via a fused socket or a fused circuit.
More about GEN24 and PV Point
GEN24
PV Point Comfort
A PC board that can be retrofitted to the inverter to supply single-phase loads via a fused socket or fused circuit, including in parallel grid operation.
Go to PV Point Comfort
PV Point Comfort
Maximum autonomy with Full Backup
With our Full Backup options, you can power your entire household with self-generated electricity during a grid failure as long as sufficient energy is available from the PV system or battery. A Fronius hybrid inverter and a battery, together with the Backup Switch* and Backup Controller*, ensure a smooth transition to backup power mode. Both switching components can be installed in the switch cabinet to save space.
Backup Switch*
Cost-effective 3-way switch for manual activation of Full Backup mode
More about Backup Switch
Backup Switch
Backup Controller*
Switch unit that automatically switches to Full Backup mode and back to standard operation
More about Backup Controller
Backup Controller
GEN24 Plus & Verto Plus inverters
Versatile hybrid inverters that allow battery storage and customized backup power solutions to be integrated
Go to GEN24 Plus & Verto Plus
Fronius Verto Plus
Reserva high-voltage battery
Smart storage solution with efficient charging and discharging powers perfectly coordinated to Fronius hybrid inverters
All details about Reserva
Fronius Reserva
Maximum performance including backup
A self-sufficient and secure energy supply—the Anzi family relies on a complete PV system from Fronius
“One advantage of the Fronius GEN24 Plus is the backup power function. If there’s a power failure, we can continue to use our self-generated electricity. This gives us even greater independence from the grid.”
- Ralf Anzi (homeowner)
Go to reference
Ein Ehepaar steht am Balkon, ihre Solar Panele sind zu sehen, die Energie in den Fronius Wechselrichter übergeben.
Did you know?
Not all PV systems are automatically blackout-capable
A combination of backup power and black-start capability in the hybrid inverter and battery enables the system to reactivate itself automatically, even without power from the grid. Our Fronius GEN24 Plus and Verto Plus hybrid inverters and our Fronius Reserva high-voltage battery boast these features, making you truly self-sufficient in your home.
