Fronius Multi Flow Technology
Energy flow management
Intelligent energy flow management for photovoltaic systems
It’s one thing to store solar energy for 24/7 use, but it’s another to seamlessly combine the output of a PV system, battery, and other power sources. Our Multi Flow Technology—featuring intelligent energy control for maximum self-consumption and optimum utilization of the storage system—masters this challenge with ease.
The direct current flows from the PV modules to the inverter, which converts it into alternating current. You can use the solar power to supply loads in the household and charge the battery. Surplus PV electricity can be fed into the grid if desired.
Household loads can simultaneously draw the electricity they need from both the PV modules and the battery storage system.
If there is surplus PV energy, it is used to supply the loads and charge the battery at the same time. When the energy consumption is higher than the yield, the solar modules and the battery storage system cover the energy needs.
The inverter can use energy from multiple AC sources to charge the battery. In addition to the PV modules, you can also integrate additional energy sources such as a wind turbine into the system.
The inverter converts the direct current from the PV modules into alternating current and manages all energy flows within the photovoltaic system.
Benefits of Multi Flow Technology
The ideal products
Benefit from Multi Flow Technology with the following Fronius inverters.
Fronius GEN24 & GEN24 Plus
Want flexible use of your solar energy even during power outages? Then installing the Fronius GEN24 as the heart of your PV system is the way to go. With the Fronius GEN24 Plus, you can even enjoy 24 hours of sun in your home, because this hybrid inverter supports battery connection, increasing your overall energy independence.
Fronius Verto Plus
The powerful Fronius Verto Plus is an excellent fit for agricultural operations, small businesses, large family homes, and multi-unit residential buildings. It easily handles complex roof layouts, varying module orientations, and mixed module types. When combined with a battery storage system, it increases your independence from the grid, and its integrated backup power function ensures you stay powered even during a blackout.
The AC charging function
Even more flexibility for the energy storage system
