MIG/MAG Welding Torches
for manual welding applications
Welder using Fronius Fortis
MIG/MAG welding torch for hard-to-reach components and tight corners
From difficult to access components to remote job sites, welding torches from Fronius are designed to cover an extremely broad range of applications. Hosepacks up to 15 meters long and torch bodies of different lengths and angles make life easier for every welder, not to mention the remote control in the handle on certain models. Welders can count on the flexibility they need with Fronius – guaranteed.
    The advantages
    Long wearing part lifetimes
    Each wearing part is designed and manufactured to deliver the longest service life and for optimal heat dissipation. For example, a high-quality copper alloy(CuCrZr) is used for the contact tips in order to extend their service life.
    Long service life
    Top-quality components maximize the service life of the welding torch. Outer tubes for the torch body made from stainless steel, high-quality hosepack components, power cables with maximum flexibility and a larger-dimensioned copper cross-section all ensure longer-lasting welding tools.
    Repairable
    Despite the long service life of Fronius welding torches, faulty parts can be easily swapped out and repaired. A comprehensive range of roughly 40 replaceable spare parts on water-cooled manual welding torches allows sustainable management of your equipment pool.
    Flexible
    The Multilock System leaves you with a wide choice of over 80 different torch bodies of different lengths and angles, affording the welder even greater flexibility. Torch bodies can also be produced to customer-specific requirements at lengths of up to 1.2 m and angles from 0-90°.
    Long service life
    Repairable
    Flexible
    Ergonomic MIG/MAG torches for professional welders
    Optimized for professional use
    Fronius welding torches represent the perfect symbiotic relationship between technology and ergonomics. The ergonomic handle with anti-slip components lies comfortably and securely in the hand, allowing the torch to be guided with ease. The ball joint and optimal weight distribution prevent fatigue during welding.
    The right solution for every application
    With a range of more than 80 different torch bodies available, the perfect combination of angle and length can be selected for components with challenging geometries. In addition, individual solutions are possible to meet customer-specific requirements.
    JobMaster: Everything is under control
    With JobMaster welding torches, the welder can use the remote control with color display integrated in the handle to get a quick overview of important welding parameters such as welding power, wire speed, and previously stored jobs, and can adjust them to the desired value.
    MultiLock - patented interface
    The MultiLock system allows for quick replacement of the burner body without having to replace the hose assembly. Thanks to its smooth 360° rotation, even hard-to-reach areas can be accessed effortlessly, while the integrated anti-rotation mechanism ensures precise locking in the 0° position. An integrated water stop prevents water from leaking out and entering the gas line when the burner body is removed.
    Highlights and options
    Perfectly cooled
    Cost efficient through robustness
    The gas-cooled MIG / MAG welding torches get the most out of any application. Perfect cooling can also maximize the service life of components and thus improve cost efficiency.
    More about gas-cooled welding torches
    Fronius MIG/MAG welding torch gas-cooled
    Water cooling system
    On water-cooled systems the cooling system has been brought forward and outward as far as possible. The shape of the contact tip means that less radiant heat is now absorbed. This alone brings a temperature reduction of up to 70 °C for the wearing parts.
    More about water-cooled welding torches
    Fronius MIG/MAG welding torch water-cooled
    Welding fume extraction
    Optimal protection for health and work environment
    Welding fumes can be harmful to health, which is why Fronius believes in extracting the welding fumes directly at the point of origin – the welding torch. Thanks to fume extraction torches, the welder and their wider working environment are effectively protected against harmful emissions.
    More about Exento fume extraction torch and set
    An overview of system connections for welding torches
    Fronius System Connector for high process reliability
    The hose pack can be connected to our welding machines in seconds with no tool required, thanks to the Fronius System Connector (FSC). It combines electricity, gas, welding wire, and control signals in a single connection.
    Unlike conventional solutions that use a union nut, the FSC cannot work loose. This prevents contact issues, heat buildup at the connection, and increased contact resistance, ensuring that the welding parameters remain stable and the weld quality consistently high.
    Fronius MIG/MAG welding torches FSC adapter gas-cooled
    Fronius MIG/MAG welding torches FSC adapter water-cooled
    1 / 2
    FSC connection gas-cooled
    FSC connection water-cooled
    Euro connection: compatible with a wide range of welding machines
    One connection, many options: our Fronius welding torches are also available with the standard Euro connection. This allows them to be connected to welding machines from various manufacturers and used flexibly with existing systems.
    In addition, we offer a compatible adapter that allows an FSC to be connected to a Euro connection so you can take advantage of the benefits of our Fronius welding torches regardless of which welding machine you use.
    Fronius MIG/MAG welding torches Euro adapter gas-cooled
    Fronius MIG/MAG welding torches Euro adapter water-cooled
    Fronius Adapter Euro/FSC for MIG/MAG welding torches
    1 / 3
    Euro connection gas-cooled
    Euro connection water-cooled
    FSC–Euro central connection adapter
    Latest Fronius torches
    Fronius MIG/MAG welding torch MTG
    MTG
    • The welding torches in the MTG product family are gas-cooled MIG/MAG manual welding torches with an output of up to 530 A.
    • The ergonomically shaped grip, a ball joint and optimum weight distribution allow for effortless operation.
    • Their robust design makes the welding torches reliable partners for all applications.
    Fronius MIG/MAG welding torch MTW
    MTW
    • The welding torches in the MTW product family are water-cooled MIG/MAG manual welding torches with an output of up to 700 A.
    Fronius MIG/MAG welding torch PullMIG
    PullMig
    • The PullMig welding torch from Fronius weighs only around a third as much as comparable models.
    • The design is so compact that there is hardly any noticeable difference in size from conventional, manual welding torches – yet the torch delivers unrivalled precision.
    • The Multilock torch body, which can be rotated through 360°, serves as the base of the torch, with a stainless steel outer pipe and integrated water stop in the hosepack.
    1 / 3
