Fronius Tauro
Designed to perform
The three-phase Fronius Tauro in the 50 kW power class promises maximum performance, even under the harshest conditions. With its smart hardware design, it not only contributes to BOS cost optimization, but also offers unprecedented flexibility in system design. The Fronius Tauro can be used to implement sophisticated roofs in both centralised (P variant) and decentralised system designs (D variant). Simplest installation and the fastest service on the market also guarantee maximum safety.
Fronius Tauro. Designed to perform.
Technical Data
Input Data
Number of MPP trackers | 3 |
Max. input current (Idc max_inverter) | 134 A |
Max. PV generator power (Pdc max) | 75 kWpeak |
MPP voltage range (Umpp min - Umpp max) | 400 - 870 V 9) |
Max. input current PV1 (Idc max, PV1) | 36 A |
Max. input current PV2 (Idc max, PV2) | 36 A |
Max. input current PV3 (Idc max, PV3) | 72 A |
Max. short-circuit current PV1 (Isc max, PV1)* | 72 A |
Max. short-circuit current PV2 (Isc max, PV2)* | 72 A |
Max. short-circuit current PV3 (Isc max, PV3)* | 125 A |
Max. power PV system PV1 (Pdc max,PV1) | 25 kWpeak |
Max. power PV system PV2 (Pdc max, PV2) | 25 kWpeak |
Max. power PV system PV3 (Pdc max, PV3) | 50 kWpeak |
Max. AC fuse size rating | 355 A |
Max. short-circuit current inverter (Isc max, inverter) | 240 A |
Max. short-circuit current string (Isc max, string) | 20 A |
Max. input current string (Idc max, String) | 14,5 A |
Number of DC connections PV1 | 4 |
Number of DC connections PV2 | 3 |
Number of DC connections PV3 | 7 |
Max. short-circuit current string (Isc max, string) - 30 A Option | 30 A |
Max. input current string (Idc max, String) - 30 A Option | 22 A |
Number of DC connections PV1 - 30 A Option | 4 |
Number of DC connections PV2 - 30 A Option | 5 |
Number of DC connections PV3 - 30 A Option | 5 |
Output Data
AC nominal output (Pac,r) | 50 kW |
Max. output power (Pac max) | 50 kVA |
AC output current (Iac nom) | 75.8A at 220Vac , 72.5A at 230Vac |
Grid connection (Uac,r) | 3~ NPE 380/220 , 3~ NPE 400/230 V |
AC voltage range (Umin - Umax) | 180 - 270 V |
Frequency (fr) | 50/60 Hz |
Power factor (cos φac,r) | 1 ind./cap. |
Max. DC fuse size rating | 20 A |
General Data
Standards | 400 - 870 V 9) |
Length | 1109 mm |
Width | 1109 mm |
Height | 755 mm |
Depth | 346,2 mm |
Weight | 92 kg |
Weight incl. packaging | 111 kg |
Protection class | IP65 |
Protection class | 1 |
Night-time consumption | 15 W |
Installation | Indoor and outdoor 4) |
Ambient temperature range | -40°C - +65°C (optional AC-disconnect: from - 30 to + 65 °C) |
Permitted humidity | 0-100 % |
Max. altitude 2) | 4000 m |
Certificates and compliance with standards | VDE-AR-N 4105, VDE-AR-N 4110, IEC 62109-1/-2, IEC 62116, IEC 61727 R25, AS/NZS 4777, CEI 0-16, CEI 0-21, EN 50549-1/-2, VDE 0126-1-1 8) |
Inverter design | Transformerless |
Cooling | Active Cooling Technologie and Double-Wall System |
Sound emissions | 68,4 dB(A) |
Interference emission class | B |
Efficiency
Max. efficiency (PV - grid) | 98,5 % |
European efficiency (ηEU) | 97,8 / 98,3 / 97,9 / 97,7 (400Vdc / 600Vdc / 800Vdc / 870Vdc) |
η at 5% Pac,r 3) | 94,90 / 96,52 / 92,87 / 91,80 (400Vdc / 600Vdc / 800Vdc / 870Vdc) |
η at 10% Pac,r 3) | 97,33 / 97,91 / 96,54 / 95,68 ((400Vdc / 600Vdc / 800Vdc / 870Vdc) |
η at 20% Pac,r 3) | 98,04 / 98,45 / 97,90 / 97,63 (400Vdc / 600Vdc / 800Vdc / 870Vdc) |
η at 25% Pac,r 3) | 97,86 / 98,44 / 98,07 / 97,88 (400Vdc / 600Vdc / 800Vdc / 870Vdc) |
η at 30% Pac,r 3) | 97,92 / 98,51 / 98,14 / 98,05 (400Vdc / 600Vdc / 800Vdc / 870Vdc) |
η at 50% Pac,r 3) | 97,99 / 98,48 / 98,24 / 98,17 (400Vdc / 600Vdc / 800Vdc / 870Vdc) |
η at 75% Pac,r 3) | 97,86 / 98,35 / 98,17 / 98,10 (400Vdc / 600Vdc / 800Vdc / 870Vdc) |
η at 100% Pac,r 3) | 97,63 / 98,16 / 98,04 / 97,99 (400Vdc / 600Vdc / 800Vdc / 870Vdc) |
Protection Devices
DC insulation measurement | Included |
Overload behaviour | Operating point shift. Power limitation 5) |
DC disconnector | Included |
Integral RCMU | Included |
Overvoltage protection devices | Type 1 + 2 integrated, Type 2 optional 6) |
DC string fusing | integrated, 15 A or 20 A |
Interfaces
Ethernet LAN RJ45 | 10/100Mbit; max. 100m Fronius Solar.web, Modbus TCP Sunspec, Fronius Solar API (JSON) 7) |
6x digital in/out + 6x digital in | Programmable interface for ripple control receiver, energy management, load control (Inputs: Voltage level low: min. 0V - max. 1.8V; high: min. 4,5V - max. 28,8V / Input resistance: 70kOhm Outputs: 5 Watt @ 12V in total for all six digital outputs when supplied internally in case of no load on the USB Port. 1A @ >12,5V to 24V per digital output when supplied externally by an external power supply but in total max. 3A) |
Emergency stop (WSD) | Yes |
Datalogger and web server | Included 7) |
WLAN | Fronius Solar.web, Modus TCP Sunspec, Fronius Solar API (JSON) |
2x RS485 | Modbus RTU Sunspec |
AC Connection Technology
Cable cross section | 35 - 240 mm² |
Conductor material | Al; Cu |
Connection terminals | Cable lug or V clamps |
Single core option (single core cable) | Cable gland: 5 x M40 (10 - 28 mm) |
Multi core option (multi core cable) | Cable gland: 1 x multi core connection Ø 16 - 61.4 mm + 1 x M32 (10 - 25 mm) |
AC Daisy Chaining option (single core cable) | Cable gland: 10 x M32 (10 - 25 mm) |
DC Connection Technology
Cable cross section | 4 - 6 mm² |
Conductor material | Cu |
Connection terminals | DC direct connection, Stäubli Multi Contact MC4 |
More information about the features of this product
