Fronius Eco
The compact project inverter for maximum yields.
The three-phase Fronius Eco in power categories 25.0 and 27.0 kW perfectly meets all the requirements of large-scale installations. Thanks to its light weight and SnapINverter mounting system, this transformerless device can be installed quickly and easily either indoors or outdoors. This inverter series sets new standards with its IP 66 protection class. In addition, its integrated all-pole string fuse holders and optional DC fuse mean that string collection boxes are no longer required.
Technical Data
Input Data
Number of MPP trackers1
Max. input current (Idc max)
44,2 A
80 A
580 - 1000 V
650 V
Nominal input voltage (Udc,r)
580 V
580 - 850 V
Usable MPP voltage range580 - 850 V
Number of DC connections6
37,8 kWpeak
Output Data
AC nominal output (Pac,r)
25 kW
Max. output power (Pac max)
25 kVA
AC output current (Iac nom)
37,9 / 36,2 A
Grid connection (Uac,r)
3~ NPE 400/230, 3~ NPE 380/220 V
150 - 275 V
Frequency (fr)
50 / 60 Hz
Frequency range (fmin - fmax)
45 - 65 Hz
Power factor (cos φac,r)
0 - 1 ind./cap.
General Data
Mains FrequencyHz
Dimension / width512 mm
Dimension / height751 mm
Dimension / depth227,5 mm
Weight35,5 kg
Weight incl. packaging39,5 kg
Degree of protectionIP 66
Protection class1
2 / 3
Night-time consumption< 1 W
CoolingRegulated air cooling
InstallationIndoors and outdoors
Ambient temperature range-25°C - +60°C
Permitted humidity0 - 100 %
Max. altitude2500 m
DC connection technology6x DC+ and 6x DC- screw terminals 2.5 - 16 mm²
AC connection technology5-pin AC screw terminals 2.5 - 16 mm²
Certificates and compliance with standardsÖVE / ÖNORM E 8001-4-712, DIN V VDE 0126-1-1/A1, VDE AR N 4105, IEC 62109-1/-2, IEC 62116, IEC 61727,
AS 3100, AS 4777-2, AS 4777-3, CER 06-190, G99, UNE 206007-1, SI 4777, CEI 0-16, CEI 0-21
Sound emissions60,3 dB(A)
Interference emission classB
Efficiency
Max. efficiency (PV - grid)98,2 %
European efficiency (ηEU)98 %
η at 5% Pac,r 3)
95,1 / 91,5 %
η at 10% Pac,r 3)
97,0 / 95,2 %
η at 20% Pac,r 3)
97,8 / 96,9 %
η at 25% Pac,r 3)
98,0 / 97,0 %
η at 30% Pac,r 3)
98,1 / 97,2 %
η at 50% Pac,r 3)
98,2 / 97,5 %
η at 75% Pac,r 3)
98,2 / 97,5 %
η at 100% Pac,r 3)
98,2 / 97,5 %
MPP adaptation efficiency> 99,9 %
Protection Devices
DC insulation measurementYes
Overload behaviourOperating point shift, power limitation
DC disconnectorYes
Integrated string fuse holderYes
Interfaces
Wi-Fi / Ethernet LANFronius Solar.web, Modbus TCP SunSpec, Fronius Solar API (JSON)
6 inputs and 4 digital I/OsInterface to ripple control receiver
USB (type A socket) 4)
Data logging, inverter update via USB flash drive
2x RS422 (RJ45 socket) 4)
Fronius Solar Net
Signalling output 4)
Energy management (floating relay output)
Datalogger and web serverIntegrated
External input 4)
S0 meter connection / Evaluation of overvoltage protection
RS485Modbus RTU SunSpec or meter connection
SnapINverter technology
Integrated data communication
Dynamic Peak Manager
Smart Grid Ready
Zero feed-in
Active Cooling
Smart Grid Ready
1 / 3
Fronius Eco
Smart Grid Ready from Fronius
Fronius SnapINverter with innovative hinged system
Fronius SnapINverters
SnapINverter
The deliberate design of the Fronius SnapINverter meets great enthusiasm of our installers and customers.
    FOOTNOTES FOR TECHNICAL DATA
    1) According to IEC 62109-1. DIN rail for optional type 1 + 2 or type 2 surge protection device available.
    2) Unrestricted / restricted voltage range.
