Fronius Primo
The communicative inverter for optimised energy management.
With power categories ranging from 3.0 to 8.2 kW, the Fronius Primo perfectly complements the SnapINverter generation. This single-phase, transformerless device is the ideal inverter for private households. Its innovative SuperFlex Design provides maximum flexibility in system design, while the SnapINverter mounting system makes installation and maintenance as easy as possible. The communication package included as standard with WLAN, energy management, numerous interfaces, and much more besides, makes the Fronius Primo a communicative inverter for owner-occupiers.
This inverter has been specially designed for the demands of the Australian market.
Technical Data
Input Data
| Number of MPP trackers | 2 |
Max. input current (Idc max) | 18 / 18 A |
Max. short circuit current, module array* | 36 / 36 A |
DC input voltage range (Udc min - Udc max) | 80 - 1000 V |
Feed-in start voltage (Udc start) | 80 V |
Nominal input voltage (Udc,r) | 710 V |
MPP voltage range (Umpp min - Umpp max) | 240 - 800 V |
| Usable MPP voltage range | 80 - 800 V |
| Number of DC connections | 2+2 |
Max. PV generator power (Pdc max) | 7,5 kWpeak |
Output Data
AC nominal output (Pac,r) | 5000 W |
Max. output power (Pac max) | 5000 VA |
AC output current (Iac nom) | 21,7 A |
Grid connection (Uac,r) | 1~ NPE 220/230 V |
AC voltage range (Umin - Umax) | 180 - 270 V |
Frequency (fr) | 50 / 60 Hz |
Power factor (cos φac,r) | 0,85 - 1 ind./cap. |
General Data
| Mains Frequency | Hz |
| Dimension / width | 431 mm |
| Dimension / height | 645 mm |
| Dimension / depth | 204 mm |
| Weight | 21,6 kg |
| Degree of protection | IP 65 |
| Night-time consumption | < 1 W |
| Sound emissions | 55 dB(A) |
SnapINverter technology
Integrated data communication
SuperFlex Design
Dynamic Peak Manager
Smart Grid Ready
Zero feed-in
