Fronius Primo
The communicative inverter for optimised energy management.
With power categories ranging from 3.0 to 8.2 kW, the Fronius Primo perfectly complements the SnapINverter generation. This single-phase, transformerless device is the ideal inverter for private households. Its innovative SuperFlex Design provides maximum flexibility in system design, while the SnapINverter mounting system makes installation and maintenance as easy as possible. The communication package included as standard with WLAN, energy management, numerous interfaces, and much more besides, makes the Fronius Primo a communicative inverter for owner-occupiers.
Technical Data
Input Data
| Number of MPP trackers | 2 |
Max. input current (Idc max) | 18 / 18 A |
Max. short circuit current, module array* | 36 / 36 A |
DC input voltage range (Udc min - Udc max) | 80 - 1000 V |
Feed-in start voltage (Udc start) | 80 V |
Nominal input voltage (Udc,r) | 710 V |
MPP voltage range (Umpp min - Umpp max) | 270 - 800 V |
| Usable MPP voltage range | 80 - 800 V |
| Number of DC connections | 2 + 2 |
Max. PV generator power (Pdc max) | 12,3 kWpeak |
Output Data
AC nominal output (Pac,r) | 8200 W |
Max. output power (Pac max) | 8200 VA |
AC output current (Iac nom) | 35,7 A |
Grid connection (Uac,r) | 1~ NPE 220/230 V |
AC voltage range (Umin - Umax) | 180 - 270 V |
Frequency (fr) | 50 / 60 Hz |
Power factor (cos φac,r) | 0,85 - 1 ind./cap. |
General Data
| Mains Frequency | Hz |
| Dimension / width | 432,5 mm |
| Dimension / height | 642,5 mm |
| Dimension / depth | 205,5 mm |
| Weight | 21,07 kg |
| Weight incl. packaging | 25,8 kg |
| Degree of protection | IP 65 |
| Protection class | 1 |
| Night-time consumption | < 1 W |
| Inverter design | Transformerless |
| Installation | Indoors and outdoors |
| Ambient temperature range | -40°C - +55°C |
| Permitted humidity | 0 - 100 % |
| Max. altitude | 4000 m |
| DC connection technology | 4x DC+ and 4x DC- screw terminals 2.5 - 16 mm² |
| AC connection technology | 3-pin AC screw terminals 2.5 - 16 mm² |
| Certificates and compliance with standards | DIN V VDE 0126-1-1/A1, IEC 62109-1/-2, IEC 62116, IEC 61727, AS 4777-2, AS 4777-3, G98/1, G99/1, CEI 0-21, VDE AR N 4105 |
| Sound emissions | 55 dB(A) |
Efficiency
| Max. efficiency (PV - grid) | 98,1 % |
| European efficiency (ηEU) | 97,5 % |
η at 5% Pac,r 3) | 85,5 / 89,6 / 88,5 % |
η at 10% Pac,r 3) | 92,2 / 96,0 / 94,8 % |
η at 20% Pac,r 3) | 94,9 / 97,4 / 97,2 % |
η at 25% Pac,r 3) | 95,5 / 97,7 / 97,6 % |
η at 30% Pac,r 3) | 95,8 / 97,9 / 97,7 % |
η at 50% Pac,r 3) | 96,3 / 98,0 / 98,0 % |
η at 75% Pac,r 3) | 96,3 / 98,1 / 97,9 % |
η at 100% Pac,r 3) | 96,2 / 97,7 / 97,7 % |
| MPP adaptation efficiency | > 99,9 % |
Protection Devices
| Overload behaviour | Operating point shift, power limitation |
| DC disconnector | Yes |
Interfaces
| Wi-Fi / Ethernet LAN | Fronius Solar.web, Modbus TCP SunSpec, Fronius Solar API (JSON) |
| 6 inputs and 4 digital I/Os | Interface to ripple control receiver |
| Datalogger and web server | Integrated |
| RS485 | Modbus RTU SunSpec or meter connection |
SnapINverter technology
Integrated data communication
SuperFlex Design
Dynamic Peak Manager
Smart Grid Ready
Zero feed-in
Active Cooling
1) According to IEC 62109-1.
2) Unrestricted voltage range.
Further information
Fronius Primo 5.0-1, Fronius Primo 6.0-1 and Fronius Primo 8.2-1 are not fully compliant with VDE AR N 4105.
