Fronius Symo Advanced
Designed to rely on.
Further developed with safety in mind: the Fronius Symo Advanced opens the next chapter in the Fronius SnapINverter portfolio. The inverter combines proven performance with new safety technology, making the Fronius Symo Advanced the future-proof choice for commercial photovoltaic systems of all sizes. The latest generation of the inverter with power categories ranging from 10 to 20 kW impresses with reliable arc protection through the new Fronius Arc Guard technology, SuperFlex Design for absolute freedom in roof planning and maximum yields through the Dynamic Peak Manager.
Technical Data
Input Data
| Number of MPP trackers | 2 |
Max. input current (Idc max) | 33,0 / 27,0 A |
Max. short circuit current, module array* | 68,0 / 55,7 A |
DC input voltage range (Udc min - Udc max) | 200 - 1000 V |
Nominal input voltage (Udc,r) | 600 V |
MPP voltage range (Umpp min - Umpp max) | 320 - 800 V |
| Usable MPP voltage range | 200 - 800 V |
| Number of DC connections | 3 + 3 |
Max. PV generator power (Pdc max) | 22,5 kWpeak |
Output Data
AC nominal output (Pac,r) | 15 kW |
Max. output power (Pac max) | 15 kVA |
AC output current (Iac nom) | 21,7 A |
Grid connection (Uac,r) | 3~NPE 4000/230, 3~NPE 380/220 V |
Frequency (fr) | 50 / 60 Hz |
Power factor (cos φac,r) | 0 - 1 ind./cap. |
General Data
| Mains Frequency | Hz |
| Dimension / width | 510 mm |
| Dimension / height | 725 mm |
| Dimension / depth | 225 mm |
| Max. current | Included |
| Weight | 39,8 kg |
| Weight incl. packaging | 46,2 kg |
| Degree of protection | IP 66 |
| Protection class | 1 |
| Night-time consumption | <1 W |
| Installation | Indoor and outdoor installation |
| Ambient temperature range | -25°C - +60°C |
| Permitted humidity | 0 - 100 % |
| Max. altitude | 3400 m |
| DC connection technology | 6x DC+ and 6x DC- screw terminals 2.5 - 16 mm² |
| AC connection technology | 5-pin AC screw terminals 2.5 - 16 mm² |
| Certificates and compliance with standards | IEC 62109-1/-2, IEC 62116, IEC 61727, VDE 0126-1-1/A1, VDE AR-N 4105, G98/1, G99/1, AS/NZS 4777.2, UNE 206007-1, CEI 0-21, CEI 0-16, NRS 097-2-1, TOR Erzeuger Typ A, EN 50549-1/-2, IEC 61683, IEC60068, IEC 63027:2023 |
Efficiency
| Max. efficiency (PV - grid) | 97,9 % |
| European efficiency (ηEU) | 96.2 / 97.6 / 97.0% |
η at 5% Pac,r 3) | 91.6 / 93.9 / 90.8% |
η at 10% Pac,r 3) | 94.2 / 96.1 / 94.7% |
η at 20% Pac,r 3) | 95.9 / 97.3 / 96.5% |
η at 25% Pac,r 3) | 96.1 / 97.6 / 96.9% |
η at 30% Pac,r 3) | 96.4 / 97.7 / 97.1% |
η at 50% Pac,r 3) | 96.6 / 97.9 / 97.5% |
η at 75% Pac,r 3) | 96.4 / 97.9 / 97.6% |
η at 100% Pac,r 3) | 96.5 / 97.8 / 97.6% |
| MPP adaptation efficiency | >99.9% |
Protection Devices
| Overload behaviour | Operating point shift. Power limitation |
| DC disconnector | Yes |
| Arc fault circuit interrupter (Fronius Arc Guard) | Yes |
Interfaces
| Wi-Fi / Ethernet LAN | Fronius Solar.web, Modbus TCP SunSpec, Fronius Solar API (JSON) |
| 6 inputs and 4 digital I/Os | Interface to ripple control receiver, energy management |
| RS485 | Modbus RTU SunSpec or meter connection |
SnapINverter technology
Integrated data communication
SuperFlex Design
Smart Grid Ready
Arc Fault Circuit Interruption Integrated
The Fronius Arc Fault Circuit Interruption (AFCI) makes each inverter NEC 2011 compliant and maintains some of the most civilized, integrated technology available today. Ensuring the utmost safety, AFCI shuts down the inverter in the event of an arc fault.
Active Cooling
Active cooling technology relies on one or more fans, which not only avoid hot spots, but also regulate the air circulation inside the inverter, thus keeping the temperature of the power electronics low. This has a positive effect on the service life of the devices, optimises yields and reduces costs. At Fronius, active cooling is supplied as standard in all devices.Clear HTML version of the operating instructions. Mobile and optimised for every device.
