Fronius Primo GEN24 Plus
Inverter for private PV systems with PV Point or Full Backup
* Additional external components for grid switchover are required for the Full Backup. More information on this can be found in the operating instructions.
Technical Data
Input Data
| Number of MPP trackers | 2 |
Max. input current (Idc max) | 22 / 12 A |
Max. short circuit current, module array* | 41,25 / 22 A |
DC input voltage range (Udc min - Udc max) | 65 - 600 V |
Feed-in start voltage (Udc start) | 80 V |
Nominal input voltage (Udc,r) | 400 V |
MPP voltage range (Umpp min - Umpp max) | 210 - 530 V |
| Usable MPP voltage range | 65 - 530 V |
| Number of DC connections | 2+2 |
| Min. MPP voltage (U mpp min) | 210 V |
| Max. MPP voltage (U mpp max) | 530 V |
Max. PV generator power (Pdc max) | 6 kWpeak |
Output Data
AC nominal output (Pac,r) | 4000 W |
Max. output power (Pac max) | 4000 VA |
| Max. grid power demand | 4000 VA |
| Max. AC output current | 25,8 A |
Grid connection (Uac,r) | 1~ NPE 220/230 V |
AC voltage range (Umin - Umax) | 155 - 270 V |
Frequency (fr) | 50 / 60 Hz |
Power factor (cos φac,r) | 0,8 - 1 ind./cap. |
| Back-up power | 1~NPE 220 V / 230 V |
| Nom. output current (220VAC) | 18,2 A |
| Nom. output current (230VAC) | 17,4 A |
Output Data PV Point
| Max continuous output power | 3000 VA |
Nom. output current (Iac max) | 13 A |
| Grid connection | 1 ~ NPE 220 V / 230 V |
| Frequency | 50 Hz / 60 Hz |
| Max. switchover time PV-Point | 15 s |
| Max. switchover time Full Backup | 10 s |
| Frequency in backup power mode | 53 Hz |
Battery Connection
| Number of DC connections | 1 |
Max. input current (Idc max.) | 22 A |
DC input voltage range (Udc min - Udc max) | 150 V - 455 V 7) |
| Max. input / output power (Depending on the connected battery) | 4140 W |
| Max. AC charging power (Depending on the connected battery) | 4,000 W |
| Min. DC input voltage | 150 V |
| Max. DC input voltage | 455 V |
General Data
| Mains Frequency | Hz |
| Dimension / width | 474 mm |
| Dimension / height | 530 mm |
| Dimension / depth | 165 mm |
| Weight | 15,38 kg |
| Weight incl. packaging | 19 kg |
| Degree of protection | IP66 |
| Protection class | 1 |
| Night-time consumption | <10W |
| Inverter design | Transformerless |
| Installation | Indoor and outdoor installation |
| Ambient temperature range | -40°C - +60°C |
| Permitted humidity | 0 - 100 % |
| Max. altitude | 4000 m |
| DC PV connection technology | 4x DC+ and 4x DC- push-in spring terminals 2.5 - 10 mm² |
| DC battery connection technology | 1x BATT+ and 1x BATT- push-in spring terminals 2.5 - 10 mm² |
| AC connection technology | 3 pole AC push-in spring terminals 2.5 - 10 mm² 3 pole backup power push-in spring terminals 1.5mm² - 10mm² 2x PE-screw terminals 2.5 - 16 mm² and 3x 2,5 - 10mm² |
| Certificates and compliance with standards | IEC 62109, IEC 62909, AS/NZS 4777.2, CEI 0-21, ABNT BNR 16149 and 16150, IEC 62116, IEC 61727 8) |
| Back-up power functions | PV Point, full backup 4) |
| Compatible batteries | BYD Battery-Box Premium HVS/HVM & LG FLEX 5) |
| Sound emissions | 42 dB(A) |
Efficiency
| Max. efficiency (PV - grid) | 97,6 % |
| European efficiency (ηEU) | 95.8 / 97.1 / 96.5 (210Vdc / 400Vdc / 530Vdc) |
η at 5% Pac,r 3) | 85.8 / 90.5 / 88.2 (210Vdc / 400Vdc / 530Vdc) |
η at 10% Pac,r 3) | 90.3 / 93.7 / 92.2 (210Vdc / 400Vdc / 530Vdc) |
η at 20% Pac,r 3) | 94.4 / 96.3 / 95.6 (210Vdc / 400Vdc / 530Vdc) |
η at 25% Pac,r 3) | 95.1 / 96.7 / 96.1 (210Vdc / 400Vdc / 530Vdc) |
η at 30% Pac,r 3) | 95.6 / 97.0 / 96.5 (210Vdc / 400Vdc / 530Vdc) |
η at 50% Pac,r 3) | 96.5 / 97.4 / 97.1 (210Vdc / 400Vdc / 530Vdc) |
η at 75% Pac,r 3) | 96.7 / 97.5 / 97.3 (210Vdc / 400Vdc / 530Vdc) |
η at 100% Pac,r 3) | 96.7 / 97.5 / 97.3 (210Vdc / 400Vdc / 530Vdc) |
| MPP adaptation efficiency | 99.9 |
Protection Devices
| Overload behaviour | Operating point shift. Power limitation |
| DC disconnector | Yes |
Interfaces
| 6x digital in/out + 6x digital in | Interface to ripple control receiver, energy management |
| Emergency stop (WSD) | Yes |
| Datalogger and web server | Included |
| 2x RS485 | Modbus RTU SunSpec (third-party supplier) / Fronius Smart Meter, battery, Fronius Ohmpilot |
Integrated data communication
SuperFlex Design
Dynamic Peak Manager
Multi Flow Technology
Full Backup
PV Point
Active Cooling
Active cooling technology relies on one or more fans, which not only avoid hot spots, but also regulate the air circulation inside the inverter, thus keeping the temperature of the power electronics low. This has a positive effect on the service life of the devices, optimises yields and reduces costs. At Fronius, active cooling is supplied as standard in all devices.Downloads
FOOTNOTES FOR TECHNICAL DATA
1) According to IEC 62109-1. Option to retrofit surge protection device DC SPD type 1+2 for 2 MPP trackers available under the following item number: 4,240,313,CK
2) Unrestricted voltage range.
3) At Umpp min. / Udc,r / Umpp max.
4) Depending on the connected battery.
5) This does not apply to the BYD Battery-Box Premium HVS 10.2, HVS 12.8, HVM 8.3, HVM 22.1 & LG RESU FLEX 17.2
6) Depending on the country-specific certification and availability
7) An AC power derating of the inverter occurs from a battery DC input voltage of 419.7 V
8) You can find the current certificates under www.fronius.com/primo-gen24-plus-cert
