Fronius Verto
Your photovoltaic system can do more
Fronius Verto, the adaptable inverter for small businesses, agriculture and apartment blocks. Its flexibility makes it the perfect choice both for the construction of a new PV system and for an extension. With integrated safety features and innovative shading management, the Fronius Verto ensures optimum operation. Sector coupling is made possible by our flexible inverter with its open interfaces. Charging boxes such as Fronius Wattpilot or consumption controllers such as Fronius Ohmpilot can thus be easily integrated.
Technical Data
Input Data
Number of MPP trackers4
150 V
Nominal input voltage (Udc,r)
600 V
Min. MPP voltage (U mpp min)150 V
Max. MPP voltage (U mpp max)870 V
45 kWpeak
Max. input current string (Idc max, String)
28 A
Output Data
AC nominal output (Pac,r)
29,99 kW
Max. output power (Pac max)
29,99 kVA
Max. grid power demand29,99 kVA
Max. AC output current53,7 A
Grid connection (Uac,r)
380/220V 400/230V 440/254V 480/277V
Grid connection (Uac,r)3~ (N)PE 380/220 3~ (N)PE 400/230
176-528V
Power factor range0-1 ind./cap.
General Data
Nominal voltage380/220V, 400/230V, 440/230V, 480/277V
Dimension / width574 mm
Dimension / height865 mm
Dimension / depth279 mm
Weight38,9 kg
Weight incl. packaging49,6 kg
Degree of protectionIP66
Protection class1
Overvoltage category (DC / AC)2/3
Night-time consumption16W
Inverter designTrafolos
CoolingActive air cooling
Ambient temperature range-40°C - +60°C
Overvoltage protection 1)
Type 1+2 or type 2
Permitted humidity0 - 100%
Sound emissions54,6 dB(A)
Efficiency
Max. efficiency97,47 %
European efficiency (ηEU)97,36 %
MPP adaptation efficiency> 99,9 %
Protection Devices
DC disconnectorIntegrated
Integral RCMUIntegrated
Interfaces
Ethernet LAN RJ4510/100 Mbit max. 100 m Fronius Solar.web, Modbus TCP, JSON
6x digital in/out + 6x digital inConnection to ripple control receivers, energy management, load management
Emergency stop (WSD)Integrated
Datalogger and web serverIntegrated
WLANFronius Solar.web, Modbus TCP, JSON, 802.11b/g
2x RS485Modbus RTU SunSpec (third-party provider) / Fronius Smart Meter
AC Connection Technology
Conductor materialAl and Cu
DC Connection Technology
Connection terminalsDC direct connection Stäubli Multi Contact MC4
Technical Data
Cable glandAC: M32 (Ø12-24.5 mm)
Prepared for
Option 1: M50 cable gland (Ø10-35 mm)
Option 2: 1.5" conduit connection PE & data communication:
2 x M32 (3xØ4.9-5.5 mm + 3xØ6.7-8.5 mm)
Grid connection(N)PE
Dynamic Peak Manager
Active Cooling
