Installers & partners
Fronius Symo GEN24
Inverters for private photovoltaic systems with backup power function
Our three-phase Fronius GEN24 inverter is the heart of private photovoltaic systems.
The Fronius GEN24 is equipped with PV Point, an integrated basic backup power function that supplies backup power to connected devices via a protected socket (as long as the sun is shining).*
The Fronius Symo GEN24 boasts a wide range of features that support a sustainable, independent energy supply. Discover the key features for installers and their customers:
/ Active cooling for a longer service life
/ Flexible and fast installation
*The Full Backup option is not available for the Fronius Symo GEN24 3.0-5.0.
Product details
Input Data
Number of MPP trackers2
Maximum PV input power10,3 kW
80 V
Nominal input voltage (Udc,r)
610 V
Min. MPP voltage ( U mpp min)246 V
Max. MPP voltage ( U mpp max)800 V
Output Data
AC nominal output (Pac,r)
9999 W
Max. output power (Pac max)
9999 VA
Max. grid power demand9999 VA
AC output current (Iac nom)
14,5A at 230Vac , 15,2A at 220Vac
Max. AC output current18,5 A
Grid connection (Uac,r)
3~NPE 400/230, 3~NPE 380/220 V
154 - 280 V
Frequency (fr)
50 / 60 Hz
Frequency range (fmin - fmax)
45 - 66 Hz
Power factor (cos φac,r)
0,7-1 ind./cap.
Back-up power1~NPE 220 V / 230 V
Back-up power1~NPE 220V / 230V
Nominal AC output current (380VAC)12,1 A
Nominal AC output current (400VAC)11,6 A
Output Data PV Point
Nom. output current (Iac max)
13 A
Grid connection1 ~ NPE 220 V / 230 V
Max. switchover time PV-Point15 s
Max. switchover time Full Backup10 s
Battery Connection
Max. input current (Idc max.)
22 A
Min. DC input voltage160 V
Max. DC input voltage531 V
General Data
Mains FrequencyHz
Width529 mm
Height595 mm
Depth180 mm
Weight24,27 kg
Weight22,75 kg
Weight incl. packaging28 kg
Protection classIP66
Night-time consumption<10 W
CoolingRegulated air cooling
Ambient temperature range-25°C - +60°C
Permitted humidity0 - 100 %
Max. altitude 2)
3 000 m / 4 000 m (uneingeschränkter / eingeschränkter Spannungsbereich)
DC PV connection technology3x DC+ and 3x DC- push-in spring terminals 2.5 - 10 mm²
AC connection technologyPV Point
Efficiency
Max. efficiency (PV - grid)98,3 %
European efficiency (ηEU)97.0 / 98.1 / 97.9 (246Vdc / 610Vdc / 800Vdc)
η at 5% Pac,r 3)
93.0 / 95.8 / 95.0 (246Vdc / 610Vdc / 800Vdc)
η at 10% Pac,r 3)
95.6 / 97.4 / 96.9 (246Vdc / 610Vdc / 800Vdc)
η at 20% Pac,r 3)
96.8 / 98.1 / 97.8 (246Vdc / 610Vdc / 800Vdc)
η at 25% Pac,r 3)
97.1 / 98.2 / 98.0 (246Vdc / 610Vdc / 800Vdc)
η at 30% Pac,r 3)
97.3 / 98.3 / 98.1 (246Vdc / 610Vdc / 800Vdc)
η at 50% Pac,r 3)
97.4 / 98.3 / 98.1 (246Vdc / 610Vdc / 800Vdc)
η at 75% Pac,r 3)
97.3 / 98.2 / 98.0 (246Vdc / 610Vdc / 800Vdc)
η at 100% Pac,r 3)
97.0 / 98.0 / 97.9 (246Vdc / 610Vdc / 800Vdc)
Protection Devices
DC insulation measurementYes
Overload behaviourOperating point shift, Power limitation
DC disconnectorYes
Interfaces
Emergency stop (WSD)Yes
2x RS485Modbus RTU SunSpec (third-party supplier) / Fronius Smart Meter, battery, Fronius Ohmpilot
Integrated data communication
SuperFlex Design
Dynamic Peak Manager
Multi Flow Technology
Full Backup
PV Point
Active Cooling
Fronius UP
Is a programme that allows the installer to upgrade a Fronius product via Solar.web – without any additional hardware. Fronius UP offers unique, new and innovative possibilities to expand Fronius products with new features according to the customers` needs at any time. This leads to maximum flexibility and future reliability.
