Installers & partners
Fronius Symo GEN24 Plus
Inverter for private PV systems with PV Point or Full Backup
Our three-phase Fronius GEN24 Plus hybrid inverter is the perfect heart for private photovoltaic systems. The Fronius GEN24 Plus with its PV Point provides an integrated basic backup power supply or even a comprehensive backup power solution with the option to connect a battery system.
The Fronius GEN24 Plus hybrid inverter enables energy self-sufficiency for electricity, heating, cooling and e-mobility with the use of a battery system. This means that the Fronius GEN24 Plus with Full Backup has a backup power solution that can even supply 3-phase loads, such as heat pumps. What’s more, the Multi Flow Technology lets the hybrid inverter supply parallel energy flows in the system, even in backup power mode.*
*The Full Backup option is not available for the Fronius Symo GEN24 Plus 3.0-5.0. Additional external components for grid switchover are required for the Full Backup. More information on this can be found in the operating instructions.
Product details
Input Data
Number of MPP trackers2
Maximum PV input power10,3 kW
Max. input current (Idc max)
25 / 12,5 A
40,0 / 20,0 A
80-1000 V
80 V
Nominal input voltage (Udc,r)
610 V
278-800 V
Usable MPP voltage range80-800
Number of DC connections2/1
15 kWpeak
Output Data
AC nominal output (Pac,r)
10 kW
Max. output power (Pac max)
10 kVA
Max. grid power demand10 VA
Max. grid power demand10.000 VA
Max. AC output current16,4 A
Grid connection (Uac,r)
3~NPE 400/230, 3~NPE 380/220 V
154-280 V
Frequency (fr)
50 / 60 Hz
Frequency range (fmin - fmax)
45-66 Hz
Total harmonic distortion<3% @Pnom (230/400VAC 50Hz)
Power factor (cos φac,r)
0,7-1 ind./cap.
Back-up power3~NPE 400 V / 230 V
Nominal AC output current (380VAC)15,2 A
Nominal AC output current (400VAC)14,5 A
Output Data PV Point
Nom. output current (Iac max)
13 A
Grid connection1 ~ NPE 220 V / 230 V
Nominal operating frequency53 Hz / 63 Hz
Max. switchover time PV-Point15 s
Max. switchover time Full Backup10 s
Battery Connection
Number of DC connections1
Max. input current (Idc max.)
22 A
Max. input / output power (Depending on the connected battery)10,3 kW
Max. AC charging power (Depending on the connected battery)10,000 W
Min. DC input voltage160 V
Max. DC input voltage531 V
General Data
Width529 mm
Height595 mm
Depth180 mm
Weight23,38 kg
Weight incl. packaging28,5 kg
Protection classIP66
Protection class1
2/3
Night-time consumption<10 W
CoolingRegulated air cooling
Ambient temperature range-25°C - +60°C
Permitted humidity0 - 100%
Max. altitude3000m / 4000m
DC PV connection technology3x DC+ and 3x DC- push-in spring terminals 2.5 - 10 mm²
DC battery connection technology1x BATT+ and 1x BATT- push-in spring terminals 2.5 - 10 mm²
AC connection technology5 pole AC push-in spring terminals 1.5 - 10 mm², 3 pole backup power push-in spring terminals 1.5mm² - 10mm², 5x PE-screw terminals 2.5 - 16 mm²
Certificates and compliance with standardsIEC 62109, IEC 62116, IEC 61727, IEC 62909, VDE 0126,
VDE AR-N4105, AS/NZS 4777.2, EN 50549, CEI 0-21, G 98, R25 7)
Back-up power functionsPV Point, full backup 4)
Compatible batteries 6)
BYD Battery-Box Premium HVS/HVM<sup>5)&amp;nbsp & LG FLEX
Sound emissions47 dB(A)
Interference emission classB
Efficiency
Max. efficiency (PV - grid)98,2 %
European efficiency (ηEU)97,9
η at 5% Pac,r 3)
95,1
η at 10% Pac,r 3)
97,0
η at 20% Pac,r 3)
97,9
η at 25% Pac,r 3)
98,0
η at 30% Pac,r 3)
98,1
η at 50% Pac,r 3)
98,2
η at 75% Pac,r 3)
98,1
η at 100% Pac,r 3)
98,0
MPP adaptation efficiency>99,9%
Protection Devices
DC insulation measurementYes
Overload behaviourOperating point shift. Power limitation
DC disconnectorYes
Interfaces
Emergency stop (WSD)Yes
2x RS485Modbus RTU SunSpec (third-party supplier) / Fronius Smart Meter, battery, Fronius Ohmpilot
More information about the features of this product
FOOTNOTES FOR TECHNICAL DATA
1) According to IEC 62109-1. Option to retrofit surge protection device DC SPD type 1+2 for 2 MPP trackers available under the following item number: 4,240,313,CK
2) Unrestricted / restricted voltage range.
3) At Udc,r
4) Depending on the connected battery.
5) This does not apply to the BYD Battery-Box Premium HVS 12.8 & HVM 8.3
6) Depending on the country-specific certification and availability
7) You can find the current certificates under www.fronius.com/symo-gen24-plus-cert
