Installers & partners
Fronius Verto
Your photovoltaic system can do more
Fronius Verto, the adaptable inverter for small businesses, agriculture and apartment blocks. Its flexibility makes it the perfect choice both for the construction of a new PV system and for an extension. With integrated safety features and innovative shading management, the Fronius Verto ensures optimum operation. Sector coupling is made possible by our flexible inverter with its open interfaces. Charging boxes such as Fronius Wattpilot or consumption controllers such as Fronius Ohmpilot can thus be easily integrated.
Product details
Input Data
Number of MPP trackers4
150 V
Nominal input voltage (Udc,r)
600 V
Min. MPP voltage ( U mpp min)150 V
Max. MPP voltage ( U mpp max)870 V
40,5 kWpeak
Max. input current string (Idc max, String)
28 A
Output Data
AC nominal output (Pac,r)
27 kW
Max. output power (Pac max)
27 kVA
Max. grid power demand27 kVA
Max. AC output current53,7 A
Grid connection (Uac,r)
50
Grid connection (Uac,r)3~ (N)PE 380/220; 3~ (N)PE 400/230
60
Power factor range0-1 ind./cap.
General Data
Nominal voltage380/220V, 440/230V, 480/277V, 400/230V
Mains Frequency60 1/s, 50 1/sHz
Width574 mm
Height865 mm
Depth279 mm
Weight38,9 kg
Weight incl. packaging49,6 kg
Protection classIP66
Protection class1
Overvoltage category (DC / AC)2/3
Night-time consumption16W
CoolingActive Cooling Technology
InstallationIndoor and outdoor
Ambient temperature range-40°C - +60°C
Overvoltage protection 1)
Typ 1+2 oder Typ 2
Permitted humidity0 - 100%
Max. altitude 2)
4000 m
Sound emissions54,6 dB(A)
Efficiency
Max. efficiency97,47 %
European efficiency (ηEU)97,36 %
MPP adaptation efficiency> 99,9 %
Protection Devices
DC disconnectorIncluded
Integral RCMUIncluded
Interfaces
Ethernet LAN RJ4510/100Mbit; max. 100m Fronius Solar.web, Modbus TCP, JSON
6x digital in/out + 6x digital inInterface to ripple control receiver, energy management, load management
Emergency stop (WSD)Yes
WLANFronius Solar.web, Modbus TCP, JSON, 802.11b/g
2x RS485(third-party provider)
AC Connection Technology
Conductor materialAl und Cu
DC Connection Technology
Connection terminalsDC direct connection Stäubli Multi Contact MC4
Technical Data
Cable glandAC: M32 (Ø12-24.5 mm)
Prepared for
Option 1: M50 cable gland (Ø10-35 mm)
Option 2: 1.5’ conduit connection   PE & data communication:
2 x M32 (3xØ4.9-5.5 mm + 3xØ6.7-8.5 mm)
Grid connection(N)PE
Dynamic Peak Manager
Active Cooling
1) A single string is technically capable of processing the full / usable MPPT current. The maximum current per MPPT is limited to 28A.
2) Isc pv = Isc max ≥ Isc (STC) x 1.25 according to e.g: IEC 60364-7-712, NEC 2020, AS/NZS 5033:2021.
